19225 Kapp Drive
Our small, black gearmotors are often copied, but our reliability, quiet operation and unsurpassed quality have never been duplicated.
With over 1500 standard/stock products, Bodine products can be found in applications as diverse as medical devices, scientific and laboratory equipment, labeling equipment, printing presses, packaging equipment, factory automation (conveyors, AGV/AMRs), and chemical pumps for the oil and gas industry. Whether you need the maintenance-free performance of a fixed or variable speed AC gearmotor, the simplicity and high starting-torque of a brushed DC gearmotor, or the servo-like precision of a brushless DC gearmotor, Bodine has the right gearmotor for your application. We offer spur, helical or planetary parallel shaft gearheads, and worm, worm/helical or hypoid right-angle gearheads. Many right-angle gearheads feature hollow output shafts. Many of our standard models are stocked for immediate delivery from our Iowa warehouse, with most others delivered within 4 weeks. Or, for larger OEM applications, let our application engineers help you design a custom solution that precisely matches your specifications.
High-performance gearmotors for over 120 years
Since 1905, Bodine Electric Company has been the leading manufacturer of small motors and gearmotors. Our wide selection of standard right-angle and parallel shaft standard gearmotors are available with a variety of windings. Our certified to ISO 9001 quality management system ensures that all our gearmotors are built to last.
We manufacture gearmotors for a range of demanding industrial and commercial applications. Our products with high IP ratings are ideal for applications designed for wet or dusty environments. Our CID1 and C1D2 rated gearmotors meet or exceed the NEC guidelines for use in hazardous locations. And our high-torque hypoid gearmotors are designed for applications that require lower energy consumption and cool operation.
