Customizing materials to meet new industry demands.
CS Hyde specializes in high performance adhesive tapes, polymer films, industrial fabrics, and silicone rubber products. CS Hyde streamlines material sourcing by making advanced materials accessible, bondable, and customizable. We have become an elite resource to navigate the complexity of advanced materials either by thickness, grade, type, finish, and cost. With material investments and converting capabilities we make sourcing manageable by supplying materials in dimensions or quantities that maximize usage, reduce waste, and ultimately reduce cost.
We utilize the most up-to-date technology to transform standard roll products into custom products. Bondable by adhesive lamination or customizable with tight tolerance slitting, sheeting, rewinding, die-less cutting or standard die cutting. With low minimums and little to no set up fees we make prototypes accessible with quick turnaround times. CS Hyde values small runs and understands with any design it may require changes or modifications. Our goal is to fabricate the best product for your production with the shortest turnaround time.
Our diverse industry relationships and series of trial and error have enabled us to expand and grow our converting solutions. Applying knowledge from past applications with our material expertise has allowed us to develop custom materials with properties specific to new industry requirements, regulations, or material alternatives. CS Hyde has an extensive portfolio, premiere manufacturer relationships, and capabilities to supply products that meet or exceed industry standards. Common challenges are met with solutions for high temperature resistance, friction/wear, substrate separation, thermal insulation, electrical insulation, substrate bonding, and masking.
