Harmonic Drive’s Family of Integrated Actuators incorporate Harmonic Drive® gear reducers and have the servo drive built into the actuator itself, eliminating the need for an external drive which greatly simplifies cabling. These actuators feature CANopen® communication and only require a single four conductor cable. Up to 127 actuators can be controlled on a single bus.
A wide range of integrated actuators extend from the tiny RSF-5B (measuring just 20mm square) to the new, powerful SHA -32 (146 mm diameter) which delivers up to 484 Nm of torque. The FHA and the SHA integrated actuators have dual absolute encoders measuring both the motor position as well as the position of the output of the actuator. Configurable I/O is also available for additional functionality controlled through the CAN bus.
With over 60 years of experience, Harmonic Drive continues to develop enabling technologies and products to meet the needs of an evolving motion control market. Our high-precision, zero-backlash Harmonic Drive® actuators and gears have, and continue to, fulfill critical roles in demanding motion control applications.
Compact RSF-5, RSA-8 and FHA Mini Actuators with Integrated Servo Drives
Harmonic Drive is a registered trademark of Harmonic Drive LLC. CANopen is a registered trademark of CAN in Automation
Harmonic Drive® is the Global Leader in High Precision Motion Control. Harmonic Drive designs and manufactures a diverse selection of standard and custom engineered servo actuators, gearheads and gear component sets. State of the art manufacturing facilities in the US, Japan and Germany enable us to serve the needs of our customers, providing high quality and reliable support and service around the globe. Sales offices are located throughout the world to serve our customers. Our sales offices are staffed with degreed engineers, working to provide the optimal solution for your Motion Control needs. Harmonic Drive’s mission is to provide motion control solutions that give our customers a competitive advantage.
