Koford Engineering manufactures high performance hall and sensorless brushless housed and frameless motors for demanding applications along with matching drives.
Brushless Motors
Best in industry efficiency and power density slotless brushless motors with speeds up to 200,000 rpm, housed and frameless motors, efficiency up to 94%, 240°C insulation, zero cog, ceramic hybrid bearings, autoclavable surgical tool motors, motors for aerospace and space applications, vacuum motors, UAV servo motors, underwater UAV thruster motors. Sinusoidal back emf for zero torque ripple when used with Sinusoidal drives for precision motion control. Hollow shaft motors. Air bearing motors for long life high speed applications. Motor sizes from 16mm up to 129mm. Output power to 1600 watts. Planetary gearboxs with nitrided alloy steel gears and needle bearings and encoders are also offered as options. Matching digital sensorless and hall sensor drives are available. Integral electronics are also offered. All Koford products are manufactured in USA.
Generators
High performance generators and matching generator boards for applications from 5 watts up to 500 watts. High speed and efficiency. Starter/ generator drives for gas turbine and micro jet applications.
