Proven Motion Control Excellence
The motion control of a system is typically one of the most important single factors that affect the overall system performance.  Whether you are simply controlling the speed of a fan or moving multiple axes in coordination while toggling a valve for precise disbursement of a fluid or gas, there is a motion control solution that will provide the exact performance needed.  OMS Motion has been doing this for more than 40 years and offers a variety of capabilities, sure to meet your system requirements.  OMS products are simple to program to produce whatever motion you require, and optional accessories make integration easy.  Applications in factory automation, semiconductor fabrication and production, laboratory instruments and equipment, are some applications OMS Motion products are currently used.
OMS Motion, Inc.
Selecting the most appropriate motion controller for any application is one of the most important decisions for the optimum results of that application. A too simple solution is like selecting shoes that are too small: you will be very uncomfortable and unable to perform well.  Where a too complex selection is expensive, has long development cycles, and modifications are cumbersome (and you can’t get those shoes wet).
OMS Motion has been successfully producing motion controls for more than 40 years.  Originally founded in the early 80’s as Oregon Micro Systems, OMS developed patented technology that provides advantages in motion control performance. Products include multi-axis controllers (up to 10-axes), fully coordinated, synchronized or independent, as well as single-axis integrated solutions. OMS has a product for almost every application.
OMS Motion found success in markets around the world, including semiconductor equipment, lab automation and life science instruments, factory automation, large- and small-scale research facilities/projects, astronomy research and others.  Currently there are OMS products in use around the world, on every continent, supporting mission critical applications.  OMS Motion has the experience, proven reliability and performance that has gained the confidence of engineers and scientists worldwide. The company’s strong commitment to their customers’ success has manifested the support of some individual product applications for more than 25 years, which is no easy task. The OMS Motion organization believes in doing the right thing, which is a testament to how they have had 40+years of success.
