Rota Limited is an innovative, quality driven company which specializes in the design and manufacture of Position Transducers: Internal & External Linear Transducers, Fluid Level Transducers (Fuel/Hydraulic/Chemical tanks), Radial Transducers and Position Switches.
Rota transducers are used throughout the world in some of the harshest environments, in the construction and agricultural industries, oil and gas – both subsea and topside, in tunneling and mining industries, where they are subject to both physical abuse and exposure to dust, salt water etc.
Specifically for the mobile hydraulic cylinder market we design the smallest, most robust linear transducers to position control / monitor hydraulic cylinders. In addition to internal transducers, Rota has a patent applied for technology where the transducer can be mounted externally which is designed for double rod steering cylinders and longer stroke cylinders.
1A Rota’s External Transducer can be seen mounted on top of the double rod combine steering cylinder
2 Rota’s Internal Transducers used for monitoring crane outrigger / stabilizers
