Application Driven Solutions® for every Industry
Rotor Clip has established itself as the global leader in the manufacture and supply of retaining rings, wave springs, and hose clamps. With over 20,000 standards and endless custom capabilities, we specialize in engineering the right part for the right application, every time.
We have built a reputation for delivering quality products and technical expertise globally. Highlighting our dedication to innovation, engineering, and exceeding customer expectations, Rotor Clip has received numerous quality awards from OEMs in nearly every industry. From medical to aerospace, automotive to oil & gas and beyond, Rotor Clip produces its products to the highest quality standard including ISO 13485, IATF 16949, AS9100, ISO 9001, and ISO 14001.
Every Ring, Every Style, One Manufacturer™
Whether you’re creating an artificial shoulder or holding two components together, retaining rings offer minimal surface preparation and reduced mass compared to cotter pins and bolts.  Rotor Clip rings are manufactured in the US and Europe to global standards such as DIN, ANSI metric and JIS. As the only manufacturer of every ring style, Rotor Clip has the most comprehensive product range.
Wave springs provide space savings and performance
Made from coiled flat wire with waves added to increase loads and deflection, wave springs have a superior force-to-work height ratio and require 1/2 the work height of traditional springs. They provide accurate/repeatable forces over a wide range of deflections. Our wave springs can be customized with ease to meet unique application requirements.
Clamps designed for easy installation and removal
Rotor Clip single wire, double wire, and constant tension band clamps offer advantages over other clamps. They are self-compensating, expanding, and contracting with temperature changes to eliminate manual adjustments. Our clamps are engineered for pneumatic and manual installation, making assembly more efficient. Since self-compensating hose clamps lack a screw mechanism, they can’t be over- or under-tightened. Reduced installation time and effort can result in cost savings.
Custom solutions for your application
Our engineers work with you from start to finish to design retaining rings and wave springs to your desired specifications. Typical modifications include thickness, diameter, or alternative materials. Learn more about why Rotor Clip is the global leader in the manufacture of retaining rings, wave springs and hose clamps at rotorclip.com
Materials Stocked For Production
Rotor Clip’s warehouses are always stocked with materials to meet the demands of the medical industry. We offer 316 stainless steel and implantable-grade materials like Elgiloy® and titanium, delivering dependable solutions for high-performance applications. All our products (retaining rings, wave springs, and hose clamps) are manufactured in accordance with ISO 13485 standards, ensuring the quality and precision required for critical medical applications. With our stocked inventory, we ensure you have what you need, when you need it—without unnecessary delays.
