Leading in Ultrasonic Detection
XX Ultrasonic Sensors perform contactless, reliable, and high-performance detection regardless of the target’s shape, texture, color, or transparency. Capable of withstanding even the harshest industrial environments, XX Ultrasonic Sensors operate in diffuse, reflex, and thru-beam models. This range of sensors even includes long distance detection models. The integral connector and the available cabling and fixing accessories make these ultrasonic sensors extremely easy to install.
XX Ultrasonic Sensors line include:
High immunity to electromagnetic interference
XX Ultrasonic Sensors are E2-certified for mobile equipment. This entails a higher immunity to electromagnetic interference even in the most demanding applications.
Detection of small targets and curved surfaces
A powerful transducer and superior electronic design have made it easy to detect small objects. The high sensitivity level of the XX Ultrasonic Sensors enables them to detect many poorly reflective and curved surfaces.
Detection over a large coverage area
In the past, attempts to detect objects over a large area with multiple ultrasonic sensors would sometimes fail due to the fact that the sensor signals interfered with each other. With the ‘synchronization’ feature of the XX Ultrasonic Sensors, it is now possible to reliably detect objects over a large area with minimal risk of cross-talk, even when the ultrasonic sensors are installed closer together!
Telemecanique Sensors
Simply easy!
Telemecanique Sensors has more than 90-year history in pioneering sensor technology. Their extensive product range, from basic proximity sensors to advanced, custom-engineered ultrasonic sensors, caters to diverse industrial needs. Aligning with Yageo’s global expertise, Telemecanique Sensors uphold their core values of Simplicity, Proximity, and Expertise, ensuring every client receives not just products but comprehensive sensor focused solutions. Learn more at telemecaniquesensors.com
