Trim-Lok, Inc. manufacturers hundreds of in-stock and off-the-shelf Edge Trims, Trim-Seals, Rubber Seals, Gaskets and other plastic and rubber profiles that can be found in nearly every industry including heavy equipment, machinery, automotive aftermarket, RV, HVAC, and more.
Trim-Lok product lines are easily customized by edge gap and bulb size requirements, as well as glue and tape options, or customers can rely on a team of highly skilled engineers to design and manufacture a custom part for their application. Their team brings high caliber mechanical design, excellent materials knowledge and strong manufacturing expertise when providing custom trim and seal solutions. Several Rubber Seal products are UL certified, and Trim-Lok is IATF 16949 and ISO 9001 certified for automotive supply assuring their customers that parts will be made to specification, on-time, with 100% traceability.
Trim-Lok is able to provide ultimate flexibility in design specializing in single and multi-material profiles and specializes in numerous rubber and plastic materials including:
RUBBER
PLASTIC
Trim-Lok’s mission is “To be the leader and trusted supplier of choice for innovative trim and seal solutions!” Trim-Lok continuously goes above and beyond each customer service request to deliver a full service solution and offers engineering design and development using the latest in 3D CAD and FEA software, reverse engineering as required, state of the art rapid prototyping, internal lab testing, materials consulting, onsite fit trials of first articles and more! It is that hands-on approach and attention to detail making certain that each part matches the customers’ requirements, and our unmatched on-time delivery, fair pricing and highly skilled ensured Trim-Lok’s steady growth!
Trim-Lok, Inc. is a well-respected and recognized manufacturer of top quality extruded plastic and rubber trims and seals. Trim-Lok provides competitively priced and innovative trim and seal solutions, along with unmatched superior service, making them a leader in the industry.
In the late 1960’s owner Gary Whitener began work on a new and innovative plastic trim used to trim the edges on motorcycle helmets. His proprietary process slit, stamped and coined steel or aluminum, extruded that metal inside a flexible PVC plastic and then roll formed the part into the Trim-Lok Edge Trim part that is commonly used in nearly every industry and still sold today!
Trim-Lok continues to push engineering limits and lead innovation within our industry with several patented parts, including our all-in-one “living hinge” Snap-In Seal for RV slide-out units that combines a flap seal and bulb seal into one uniquely designed part. After installation the bulb “snaps” into place eliminating the need for additional labor and parts. Trim-Lok’s “living hinge” has translated into other patent pending designs.
